Site HomeAbout 400GreyBikeBuyers GuidesDocument LibraryIt is currently Sat Dec 16, 2017 6:26 am
Compatibility between clutch starter and CDI
Forum rules Please can you post items for sale or wanted in the correct For Sale section. Items / bikes for sale here will be removed without warning. Reasons for this are in the FAQ. Thanks
  • Author
  • Message
Offline
ylionel
Re: Compatibility between clutch starter and CDI
PostThu Aug 10, 2017 9:14 am
Ok so, i have contact one garage this morning.
The girl said : Your motor is correct for your motorcycle, i have not has been changed.
But your number for the CDI is normally 32900-10D00 not 32900-10D60, you have a motorcycle 92, so your CDI has not compatibility for your problems !
So i will take a order for a CDI today :)
Thank's for your help !
Offline
ylionel
PostWed Aug 16, 2017 10:23 am
I have received a GOOD CDI for my bandit 400
But doesen't work !
Can you help me ?
Offline
ylionel
PostWed Aug 16, 2017 1:48 pm
Ok i have a spark but, this motor not start ! :/
I think my spark Do not arrive at the right time
you think it's my rotor ?
Offline
ventYl
  • Bike owned: GSF 400 Bandit
PostThu Aug 17, 2017 12:50 pm
IDK if timing wheel can be mounted wrong but you can check the timing. You need to remove valve cover and left engine cover (better tilt bike on right so no oil will drip out of engine). Details on process are described in workshop manual.
Also, are you sure your coils are wired up properly? Try to swap HT wires between coils (IIRC left coil should fire outer cylinders, right coil should fire inner two).
Previous
Return to Bandit - Workshop
Who is online
Users browsing this forum: No registered users and 1 guest
cron
