gk76a tps sensor voltage setting
Nobbsie
Reactions:
Post by Nobbsie » Tue Oct 29, 2019 5:31 am
does anyone know what the set up voltage should be at idle and full throttle from the output?
cnt seem to find the numbers anywhere.
Nobbsie
moforockband
Reactions:
Bike owned: GK73a SP CRM250 mk3
Re: gk76a tps sensor voltage setting
Post by moforockband » Tue Oct 29, 2019 9:58 pm
Not sure if anyone will ever know, but try copy the rgv250 volts, should be similar. Are you trying to diagnose a faulty one?
Nobbsie
Reactions:
Post by Nobbsie » Wed Oct 30, 2019 6:42 am
Na trying to work out how to set it up with a new set of carbs, I guess I’ll take a look at the rgv, what have others done?
