yoshi tmr/mjn Vs fcr33
- Reactions:
Does anyone have real world experiance? I herd that the yoshi tmr/mjn are better for low to mid power, is this true?
P.s with them being 32mm you could keep higher intake velocity?!
- Variablevalves suck
- Reactions:
Re: yoshi tmr/mjn Vs fcr33
Hi,
They are basically the same by different manufacturers so only slight differences.
I have TMR's on my sp and they come with the low speed pump and a choke, im sure FCR have no choke and the pump is an add on, may be wrong.
They come in 28 mm out to 33 mm so lots of choice in diameter.
- Reactions:
Kool thanks for the info!
Nobbsie
Nobbsie
- Reactions:
i looked at the idea of getting a set of zxr400 carbs spaced out for the 76a, only for the reliability and to see if some sort of ram airbox could be set up.
