Odd oil leak 76a
- monkers
- Reactions:
- Bike owned: GSXR400R
Odd oil leak 76a
I have an odd one. I've had the bike on a paddock stand and the garage floor was clean. Put it on the side stand, started leaking. Put it back on paddock stand, all good.Before I get in there and clean it all up I wondered if there was a known weakness somewhere anyone is aware of. If I didn't know better I'd say it was an overflow thing but there isn't enough oil in it for that.It's not a pressure thing either, leaks whatever temp.
All very vague I know but hey
There are no secrets, you either know it or you don't.
- Reactions:
Re: Odd oil leak 76a
Clutch pushrod, gearchange shaft or output shaft oil seal.
- monkers
- Reactions:
Thanks, I've taken the cover & sprocket off so I can look properly. It seems to be coming from the gear selector sensor, well at least there is oil behind there. Anybody any experience of this? Next steps?willandrip wrote:Clutch pushrod, gearchange shaft or output shaft oil seal.
- Reactions:
Look at the parts fiche...if there is an o ring..get one and swap it over...
the seals will be 25 is years old..
