suzuki GK74a
Posted: Thu Apr 03, 2014 1:19 pm
by Richynysmon
Hello has any one else got one of these Suzuki GSXF40
0
Re: suzuki GK74a 400 compression readings
Posted: Mon Jun 16, 2014 1:23 pm
by Richynysmon
Compression readings
1 -110 psi
2-90 psi
3-90 psi
4-100 psi
can any confirm correct reading these seem low Bike runs but smokes and doesnt sound right
going to strip engine down but just want to check before i start
Re: suzuki GK74a
Posted: Thu Jul 02, 2015 2:14 pm
by Variablevalves suck
The standard psi (using the Suzuki tester) is around 140.
The fact that they are all close would lend towards being ok and your tester reading low, id check again and if the same you could add a very small amount of oil to see if this gives a better reading due to sealing the rings.
There's a good chance that if its smoking the carbs need a rebuild, if you got a temp gauge check its not reading low due to a rich mixture.
