GK76a O rings and float bowl gasket
- Reactions:
Hi guys,
Below is an ebay link to a set of GK76a float bowl gaskets I got in error - mines a 73a. If anyone from here wins I'll chuck in nearly all the o rings you need to overhall the carbs. Just missing 2 x 3.5mm rings which aren't too hard to locate.
I will include:
4 x BS010
4 x BS011
4 x 10mm by 1mm
2 x 3.5mm by 1mm
All are in Viton - just tell me when you pay your from here and I'll post the lot together. The gaskets cost me £29.45 and bidding starts at £15 so get em cheap!
Check the part number before you buy though please.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0312907697
I will include:
4 x BS010
4 x BS011
4 x 10mm by 1mm
2 x 3.5mm by 1mm
- Reactions:
- Bike owned: nc29 nc30 gsxr750 T675 CRF450
Re: GK76a O rings and float bowl gasket
where'd you find the gaskets, I need a set for my 73a.
- Reactions:
Suzuki dealer up the road. If you find any 73a float bowl gaskets can you post the part number for me too please?
- Variablevalves suck
- Reactions:
Hi Logan,
The gk73 shares the same carb body as the Bandit4 BUT internals are different, you can order B4 gaskets from Suzuki uk No. 13258-44B00 as the B4 was officially imported.
- Reactions:
Legend mate thanks for the info!Variablevalves suck wrote:Hi Logan,
