GK71F Having some electrical (?) issues
- One Hit Wonder
- Reactions:
Hi all,
I have an imported GSX R400 that I picked up a little under a year ago. Recently as I was going to ride it home from the gym it started having issues a minute or so after I cranked it up. It was bogging down, would only run with full choke, was making no power and the tach stopped working. I had to push it home and the next day I fired it up and it worked fine (tach worked, sounded fine, held idle) until it got up to operating temp then it had the same issues as before. I thought It was the ignition coils that were failing so I replaced those and no luck, it still has the same issues.
Before I throw more money at it does anyone have any idea what might be causing this? Im assuming its the an issue in the igniter unit (part #32900-32b10) but if anyone knows how to test it or could point me in the actual right direction Id really appreciate it.
- Reactions:
Re: GK71F Having some electrical (?) issues
Silly question, but what state is the battery in? Are you sure the charging system is working properly?
- Reactions:
Try and determine which cylinder is dead, if it's a pair (1&4) or (2&3) Than it is one of the Pass Transistors in the Ignitior. It can be replaced....keep us posted on your findings.
