changing speedo from kph to mph
jaybe64
Reactions:
Bike owned: 1988 kawasaki ZX 400 G
Post by jaybe64 » Mon Mar 16, 2015 11:24 pm
hi can anyone please help me ? :whistle: I have an old ZX 400g which is in kph and I want/have changed it to zxr 400 mph one , easy enough . now the question :- the old speedo ( KPH ) has the three restrictor wires ( connector) on the dial ( same as zxr restricted type ) well the mph ( ZXR mph one ) doesn't have the wires on it , so do I have to bridge the wires on the main harness where it would have plugged in or what do I do ( three wire block connector ) ? :oops: I have also got the British ecu ( blue label with M ) which I have read on another form is the British derestricted version ." please someone must know" . I know how to derestrict the kph one ( remove plastic inside dial its self )
richyrd5
Reactions:
Re: changing speedo from kph to mph
Post by richyrd5 » Wed Feb 10, 2016 11:08 am
Yup.i need some info on doing this as well...did you find out after chap??
richyrd5
Reactions:
Post by richyrd5 » Thu Feb 11, 2016 9:49 pm
You have to either do resistor mod or get cable converter...i think the resistor mod is easiest for you as you have mph clock...10k 1 watt resistor on pink wire then earth it..easy!!
Return to “ZXR - Workshop”
