Italian ZXR - Battery lowly recharge
- Reactions:
Re: Italian ZXR - Battery lowly recharge
No way, i am very lucky.
The rotor on the crankshaft had cutted 1 of the 3 cables that come out from the stator.
The issue was very simply to identify once opened the carter.
I've fixed it and now the bike runs perfectly.
Even the battery, nearly dead returned to life.
- Reactions:
Well done on the repair.terrem wrote:
And, my mechanist said to me that if the generator was broken, the bike cannot run for 20 km: the ignition of cilinder would empty the battery and then the bike would turn off. But i can take long trips like 50-100 km...
Anyway, the ipothesis of my mechanist is: if the generator is broken, the flattening of your battery would be so fast that you couldnt even get home. Like 10-20 km. Not 200.
So what did your mechanist say when you told him how you fixed it. ?
- Reactions:
my mechanist sai that he had checked wiring only externally the carter and they was not interrupted and that is very uncommon that a rotor could cut wirings. But as he said, the bike has 9 previous owners, so maybe someone installed a new alternator and didnt checked the wirings route correctly.
- Reactions:
No; You wrote the "mechanist" stated the bike would NOT run for more than 20 kilometers with a faulty generator so it could not be the generator causing the battery to be incorrectly charged.
Upon advice from the forum members you have found that all 3 phases need to operate and given information of how to check them. Once the generator was checked and repaired the battery is charged correctly.
The "mechanist" gave you the incorrect information.!
- Reactions:
sorry i thinked that you asked me what mechanist said when i told him where was the problem.
- Reactions:
Good job on the fix anyhow.
Post up a pic of your bike in an exotic Italian location .
- Reactions:
I live in Sassuolo, where probably had been produced all the tiles of your houses in the 80's and 90', and very very very near Maranello, where ferrari cars borns.
do you prefer as background some crate of tiles or a ferrari?
- Reactions:
Ha ; I see your predicament.
Just a pic of the bike will do.
I have no ZXR 400 only its bigger brothers.
This L2 track bike
and a standard colours L1 with a 900 engine.
This L2 track bike
