Which forks?
tanuki
Reactions:
Which forks?
Post by tanuki » Thu Jun 12, 2008 5:17 pm
I believe that there are some later model 636 radial brake forks that fit the ZXR400 yokes?
Is this true?
Si
Reactions:
Re: Which forks?
Post by Si » Fri Jun 13, 2008 11:59 am
yeah the zx6r forks fit the zxr400l yokes
not sure of the prefix for the fork legs but I think its the c1h models
tanuki
Reactions:
Re: Which forks?
Post by tanuki » Fri Jun 13, 2008 12:11 pm
and are they radial jobbies?
Si
Reactions:
Re: Which forks?
Post by Si » Fri Jun 13, 2008 2:24 pm
Ballsout Racing
Reactions:
Re: Which forks?
Post by Ballsout Racing » Sat Jun 21, 2008 11:57 am
2003/2004 is what I used. 2005/6 will also work but the disks are bigger so don't mix years without checking wht works with what. They're 25mm longer than the 400 forks so will need that showing above the yokes.
http://www.zxrworld.co.uk/zxr400oc/down ... &mode=view
too fast
Reactions:
Re: Which forks?
Post by too fast » Wed Jul 23, 2008 10:46 am
are the spring rates about right for the 400?
Ballsout Racing
Reactions:
Re: Which forks?
Post by Ballsout Racing » Thu Aug 07, 2008 9:33 pm
They're 8.5kg instead of 8. So perfect for track. Maybe a bit stiff for the road and if you're a lightwieght ;)
