Rrsp crankshaft
- Reactions:
Rrsp crankshaft
Right lads is it at all possible to have crank repaired, ground with new shells, metal sprayed, ground new shells, anyone with experience with good machine shop recommendations ?
Or is there a good shaft out there to buy?
What other versions of crank can I fit if no rrsp ones available? Genesis ? Help !
Sent from my iPad using Tapatalk Pro
- Reactions:
Re: Rrsp crankshaft
I think the crank is the same as the RR the problem will be finding shells
- Reactions:
Re: Rrsp crankshaft
Evilchicken0 wrote:I think the crank is the same as the RR the problem will be finding shells
- Reactions:
Re: Rrsp crankshaft
Shells seem to be available from fowlers
- Reactions:
Re: Rrsp crankshaft
I guess you have the motor stripped - has the crank picked up badly ???
- Reactions:
Re: Rrsp crankshaft
Very minor marking may try to polish out with wet n dry and see how it looks after that!
- Reactions:
Re: Rrsp crankshaft
Why not seach "motorcycle crankshaft services" and under seach tools change it to UK only. Then ring up a few companies and see what they say
- Reactions:
Re: Rrsp crankshaft
Nah refurb onlY answer waiting on replies from a few emails to refurb shops..
- Reactions:
Re: Rrsp crankshaft
SEP Kegworth S.E.P. Kegworth - 39 Sideley Road
Kegworth, Derbyshire, DE74 2FJ
Telephone: 01509 673295
Fax: 01509 673244
Email: info@sep-kegworth.co.uk
Motor and Motorcycle Engineers
High Class Reconditioners
For the fastest possible service
CONTACT US TODAY
All SUZUKI, KAWASAKI, YAMAHA, and HONDA crankshafts
THERMO-COATING and REGRINDING SPECIALISTS
LINER MANUFACTURERS with FULL MACHINE SHOP facilities
COLLECTION and DELIVERY SAME DAY to all parts of the British Isles
ENGINE REBUILD SPECIALISTS
CYLINDER HEAD RECONDITIONING
Line Boring
Valve Seat Fitting
Valve Guides
CRANKSHAFT & BIG END assembly made to pattern
VINTAGE & VETERAN Engine parts remanufactured to specification
REPAIRS for the RACING fraternity a SPECIALITY
Only 500 yards from the M1 and 1 mile from East Midlands Airport
Monday - Friday 8am-5pm.
Saturday 8am-12.30pm.
Specialize in all reconditioning on motorbike engines & cars.
All work guaranteed with written quotes. Call Ken, Gavin or Alistair for advice.
Honda, Suzuki, Kawasaki, Yamaha
MORE INFORMATION
Anyone used these guys before?
Fax: 01509 673244
CONTACT US TODAY
Line Boring
Valve Seat Fitting
Valve Guides
MORE INFORMATION
- Reactions:
- Bike owned: 2x3tj xs650
Re: Rrsp crankshaft
You might be able to get it ground to fit these.
http://www.ebay.co.uk/itm/YAMAHA-FZR400 ... Swxg5XyLNK
