fzr600rrsp
Purpletoddy
Reactions:
Re: fzr600rrsp
Post by Purpletoddy » Wed Aug 16, 2017 6:56 am
bike is looking good mate, glad to see you kept hold of it in the end and working through the issues that arise.
The suspension will make a huge difference I bet :peace:
icklepob
Reactions:
Re: fzr600rrsp
Post by icklepob » Tue Sep 05, 2017 2:59 pm
Well, suspension back and it's easy to see why it was handling poorly.
200ml less oil per leg than spec, and piss thin too. Now 15w oil and 80ml air gap. New seals and good to go
Shock opened up and frothy oily tango was in there. All rebuilt and regassed. ImageImageImage
Reactions:
Re: fzr600rrsp
Post by Evilchicken0 » Wed Sep 06, 2017 9:19 am
That should be a lot tighter. Is that small spring in the forks for top out ?
icklepob
Reactions:
Re: fzr600rrsp
Post by icklepob » Wed Sep 06, 2017 10:49 am
Evilchicken0 wrote:That should be a lot tighter. Is that small spring in the forks for top out ?
Hoping so. Just hoping the base setting is somewhere near
Yeah,it's the top out. Not that it needs it with 15st on it [FACE WITH TEARS OF JOY][FACE WITH TEARS OF JOY]
Sent from my SM-G950F using Tapatalk
Reactions:
Re: fzr600rrsp
Post by Evilchicken0 » Wed Sep 06, 2017 1:41 pm
I hear you on that score bighug
icklepob
Reactions:
Re: fzr600rrsp
Post by icklepob » Wed Sep 06, 2017 2:09 pm
My racing whippet days are well over. Just want to smile and have fun now
icklepob
Reactions:
Re: fzr600rrsp
Post by icklepob » Sat Sep 09, 2017 1:17 pm
Suspension was near perfect. A little softly sprung on the rear meant having to wait before throttling on corner exit due to the bike squatting and pushing wide, but compression damping helped a little. Front was mint.
icklepob
Reactions:
Re: fzr600rrsp
Post by icklepob » Sat Sep 09, 2017 1:19 pm
Few videos,not in time order, of the Anglesey classic bike trackday.
Starting to get back to grips with a sportsbike after so long on naked bikes and sitting up.
Still not at full race pace, and was being respectful of other riders on track,but starting to feel happy in the bike, and mojo appears to be back.
1 https://youtu.be/tDxYsZ_6HgE
2 https://youtu.be/TRivepJ4eRU
3 https://youtu.be/e9Gz872c3oc
4 https://youtu.be/6pbxxtRiL2g
5 https://youtu.be/4jK_AWXYQrM
icklepob
Reactions:
Re: fzr600rrsp
Post by icklepob » Tue Jan 23, 2018 8:12 pm
New ali clock bracket and koso copy clock fitted (needs finishing off) and now got no fault codes on the clocks. Was showing code 8, fuel sender, and no matter what was tried, couldn't sort it. Turns out the Cdi was kaput but it's running the bike fine, and never showed fault before. Ah well, was only a tenner for a new One, so all good.
