Blue smoke???
goonerruss
Reactions:
Blue smoke???
Post by goonerruss » Thu May 15, 2008 6:00 pm
Hi all, got myself a 1992 FZR400RR, have noticed some blue smoke from the exhaust on start up and occaisionally while riding? when i open up the throttle the smoke clears, when i shut the throttle off & open up again some blue smoke appears?? have been told it's more than likely valve stem oil seals, has anyone experienced this before? if so how easy was it to repair? with the lack of a workshop manual to work from i'd be kinda working blind!!
Any help or advice would be great, thanks
oollit
Reactions:
Bike owned: FZR400RR 3TJ, RF900R
Re: Blue smoke???
Post by oollit » Thu May 15, 2008 6:09 pm
That does sound like the valve stem oil seals have gone.
I haven't replaced them before but i am going to be overhauling my 3TJ engine shortly and i will be stripping the head so if you still need advice in a couple of weeks time i might be able to help.
I only please one person per day.
Today is not your day, tomorrow isn't looking good either.
goonerruss
Reactions:
Re: Blue smoke???
Post by goonerruss » Thu May 15, 2008 6:13 pm
ok thanks, give me a shout when you've done the overhaul.
Reactions:
Re: Blue smoke???
Post by Evilchicken0 » Thu May 15, 2008 10:48 pm
Get it compression tested.
You can do a "dry" test and if it's low or leaks down you follow it with a "wet" test. This is some oil down the barrels, if this holds it's compression it's the rings (as the oil seals the cylinder better) if it still loses its the valves not sealing.
Alothough you can do the oil seals with the head on the engine it will be easier if it's off. Consider honing the bores too.
Rover220
Reactions:
Re: Blue smoke???
Post by Rover220 » Fri May 16, 2008 8:24 pm
Evilchicken0 wrote:Get it compression tested.
valve stem seals, not rings so dont worry yourself that it needs serious work.
Reactions:
Re: Blue smoke???
Post by Evilchicken0 » Sat May 17, 2008 12:42 am
Don't you need to take the cams of and the collets that stop the valves dropping and the valve springs ... so don't you need to take head off in case you drop the valve and so you can get the spring compressor on .... ????
So given that you might as well compression test it and if there's any leak down now is the time to sort it out.
dobbslc
Reactions:
Bike owned: 3TJRRSP TRX850 XV750 cafe
Re: Blue smoke???
Post by dobbslc » Sat May 31, 2008 7:24 pm
You can get a gadget that blows air down the plug hole that keeps the valves in place while you work on the stem seals. :)
