Won't start
- Reactions:
- Bike owned: FZR 400 RR SP
Re: Won't start
No problem Evil.
- Reactions:
Re: Won't start
These are some rough measurements of zxr400l valves.
in dia 17mm length 84mm.
ex dia 22mm length 85.5mm.
I don't know the stem dia.
- Reactions:
Re: Won't start
Thanks for dimensions, will check this weekend as I am away until then.
- Reactions:
Re: Won't start
Funny how things work out.
A month ago I had a completed bike ready to tax.
It would not start due to what I believe was lack of compression due to some tight valve clearances the compression gauge that told me "all was ok" was taken by the recycling van a month ago.
During the fault finding process i have identified High Tension side electrical problems
In the last month I have stripped the top end
Had the valves ground and the seats re-cut
had the head skimmed
Rebuilt the head and achieved all the correct valve clearances.
Now ready to rebuild this weekend
I just bought this bike cheap to do a cosmetic job and ride to the North West 200
I have everything I need to complete the bike but will I finish it in time to get there?
If its not finished I have a Triumph Sprint which I can use
How things have changed from my youth that a Triumph may be more reliable than a Yamaha
Funny old World!
Having 16 valves is a pain in the arse on the work bench but I suspect different on the road.
Will keep all posted regarding my own race to get to the North West
Funny old World!
- Reactions:
Re: Won't start
Arf !!!
On the flip side though, you'll have a fully sorted FZR which will be rewarding to ride and you'll probably find it quite reliable. They are getting to be older bikes now and will need a bit of engine work, but that should see them good for a while afterwards maybe another decade. They do tend to suffer from first time owners though.
$ valves a cylinder, tis witchcraft
- Reactions:
Re: Won't start
Just a few further irritating questions as I intend putting it back together this weekend between getting a few miles in on the 750 turbo.
Sealant on the base gasket?
Sealant on the head gasket?
Anything else to what out for?
I have made 4 ring compressors from plastic waste pipe to be held in place by zip ties to compress the piston rings when putting the barrels back on.
- Reactions:
Re: Won't start
No sealant on either gasket.
You only need 2 compressors, 2 cylinders are up and 2 are down. Put a piece of equal sized wood / alloy under the front and back of the 2 pistons your feeding in - this locks them and keeps them perpendicular to the block
- Reactions:
Re: Won't start
Reason for 4 is that they are cheap an easy to make and when the first two pistons are in you don't have to F about trying to fit the next two as they are already on. Used the technique for years. I will try to video it and stick it on YouTube but I am shit at that sort of thing.
- Reactions:
Re: Won't start
Cool - you have a lot more experience than me
- Reactions:
Re: Won't start
I doubt that Evil, I generally do most things twice to get them right.
