CLUTCH PLATES
LKey
Reactions:
CLUTCH PLATES
Post by LKey » Wed Mar 27, 2019 9:48 am
Hi all,
The steel plates of my 2TK clutch are 2mm to 2.05mm thick.
I'm looking for matching steel plates with a thickness of 2.3mm to 2.8mm
Does anyone know a source for thicker plates?
Are there any other models with matching plates?
buzzawak
Reactions:
Re: CLUTCH PLATES
Post by buzzawak » Wed Mar 27, 2019 11:34 am
i would love to know why you want thicker plates ?
LKey
Reactions:
Re: CLUTCH PLATES
Post by LKey » Wed Mar 27, 2019 12:01 pm
I'll need a bit more clearance when using a slipper clutch
Reactions:
Re: CLUTCH PLATES
Post by Evilchicken0 » Thu Mar 28, 2019 3:03 pm
I don't know and source for that … the 600 3he, 4JH foxeye and Thundercat will probably it but I don't know the thickness. Maybe a the 750 or 1000 fzr / thunderace, you might be able to get 1 to see if it fits.
Failing that could you try to get more throw on the slave mechanism
Have you asked the makers of the slipper clutch what they might do, or if yours is from a different bike to the 2tk what the plates are
buzzawak
Reactions:
Re: CLUTCH PLATES
Post by buzzawak » Fri Mar 29, 2019 3:05 am
Very interesting
LKey
Reactions:
Re: CLUTCH PLATES
Post by LKey » Tue Apr 02, 2019 3:40 am
Problem solved
I bought 2 Barnett plates 1.4mm thick
