Radiators and 17" Rear Wheels for my 1WG
tehd3thst4r
Reactions:
Re: Radiators and 17" Rear Wheels for my 1WG
Post by tehd3thst4r » Sun Jun 17, 2018 8:47 am
Splendid!
Do you know if I'll have to use the 400 fan or will the 600 fan fit? I also assume that the 600 hoses will work without too much hassle.
BlueR32
Reactions:
Post by BlueR32 » Sun Jun 17, 2018 12:56 pm
The 400 fan won't mount to the 600 radiator. Check out pics of the 600 fan and you will see why.
tehd3thst4r
Reactions:
Post by tehd3thst4r » Thu Jul 05, 2018 4:21 am
While looking for a thundercat front end; I saw something about swapping a 91-94 FZR1000 USD front end onto the 400.
Anyone have experience with that swap?
Reactions:
Post by Evilchicken0 » Thu Jul 05, 2018 5:39 pm
The FZR1000RU front end will go in but the front wheel doesn't have a mechanical speedo, the brake discs are 320mm which is a bit big.
tehd3thst4r
Reactions:
Post by tehd3thst4r » Thu Jul 05, 2018 5:59 pm
No mechanical speedo? Well that answers that question.
I'm also strongly considering the R6 swap because I don't like the top clamp from the T-Cat... the recesses for the clipons look super ugly when the bars are underneath. Was the problem with the R6 front just the alignment of the lock?
Reactions:
Post by Evilchicken0 » Fri Jul 06, 2018 1:36 pm
Why not use a 1989 3en2 top yoke - it's flat with the clip-ons underneath and 41mm forks, same as the T'Cat
Reactions:
Post by Evilchicken0 » Fri Jul 06, 2018 1:38 pm
tehd3thst4r
Reactions:
Post by tehd3thst4r » Fri Jul 06, 2018 6:14 pm
This will pair with the T-Cat bottom yoke?
This would probably be the smartest and cheapest option.
Reactions:
Post by Evilchicken0 » Sun Jul 08, 2018 8:19 pm
Should do ... theyre both 41mm dia forks
tehd3thst4r
Reactions:
Post by tehd3thst4r » Sun Jul 08, 2018 8:48 pm
Yeah, but I'm worried that the spacing might be different.
