mirrors
- Reactions:
Re: mirrors
I thought about itand even got a pair of Gix750 mirrors to go on because they had a longer stem. Then other things happened anddidn't do it.
The Gix mirrors mounts are 2mm or so out of line - I was just going to file the holes out. http://www.mandp.co.uk/productinfo/5473 ... Two-Wheels" onclick="window.open(this.href);return false;
A lot of aftermarket stuff is cheap in build quality and the designs try to hard to be different ending up looking gash. You need them to work with the bike.
- Reactions:
- Bike owned: 85 GSXR7/11, 06 Bandit 12
Re: mirrors
My mate said he'd heard that ZXR mirrors fit so I thought i'd check on here 1st;) I guess we'll have to settle for a set of black o/e ones, the ones on there are white but starting to look tatty now:(
- Reactions:
Re: mirrors
Measure the bolt spacing and the angle of the baseplate then you can get an idea of what fits.
- Reactions:
Re: mirrors
I fitted r6/r1 mirrors to mine.
took the base plate off the original mickey mouse ears and then fitted the r6 mirror stems into it.
needed to file the mirror stem mounting hole a touch to fit but all good now. :)
- Reactions:
Re: mirrors
They look good What year are they from cheers
- Reactions:
Re: mirrors
they were fleabay specials.
about £30 and IIRC around 98/99 ish
- Hogdigerdy Dog
- Reactions:
Re: mirrors
they look pretty good and decent long stems on em too,
i got fzr1000 mirrors on mine (well the add said fzr400,600,750,1000 mirrors but there rounder than the 400 jobbies) i also had to make some spacers to fit between the mirror bracket and cockpit subframe so they don't pinch the fairing and without some major contortion all i can see in mine is me elbows
viewtopic.php?f=62&t=17345
- Reactions:
- Bike owned: FZR400RR
Re: mirrors
i have some aftermarket mirrors on mine,
they just bolt strait on, dont look too bad either...
dont have a clue what they are though, maybe one of you lot will know...
il post a pic when i get back in :)
- Reactions:
Re: mirrors
http://s959.photobucket.com/albums/ae80/jwpearson
there's mine, as evil said, build quality isn't great, but on the plus side, i can see more than just my elbows out of them...
(couldn't get pictures to work but waheyy.)
