FZR400 oil cooler mounting brackets
Posted: Tue Feb 23, 2021 2:16 pm
by macbook
Hello, does anyone have a set of oil cooler mounting brackets they would sell?
Re: FZR400 oil cooler mounting brackets
Posted: Sat Feb 27, 2021 7:34 pm
by Evilchicken0
It was only the 2tk that had a cooler I think so you might have to make them
Posted: Sat Feb 27, 2021 7:41 pm
by Evilchicken0
Posted: Sun Feb 28, 2021 4:33 pm
by MadMotoUK
The 3HE (1989ish) FZR600 has a cooler. As the frame and engine castings are pretty similar, if not near identical on paper, maybe this could be a source? You'd have more luck than specifically searching for 2TK parts.
EDIT: I'm assuming the 2TK has an oil cooler mounted inline with the oil filter?
Also, the FZ400 has an oil cooler (as well as water cooling), but these are probably as rare as, if not rarer than, the 2TK. I've never known one other than mine in the UK.
Posted: Mon Mar 08, 2021 7:09 pm
by macbook
Thanks, everyone for the input. I have solved my issue and then some. I have ended up gathering two complete used systems from Japan. At some point I will sell one it anyone is interested.
Posted: Fri Mar 12, 2021 3:56 am
by macbook
Thanks every one for your help. I have found a set in Germany ebay NEW! and a 2TK part number!
