FZR400 oil cooler mounting brackets
macbook
Reactions:
Bike owned: fzr400 x 4 + Ducati
Post by macbook » Tue Feb 23, 2021 2:16 pm
Hello, does anyone have a set of oil cooler mounting brackets they would sell?
Reactions:
Re: FZR400 oil cooler mounting brackets
Post by Evilchicken0 » Sat Feb 27, 2021 7:34 pm
It was only the 2tk that had a cooler I think so you might have to make them
Reactions:
Post by Evilchicken0 » Sat Feb 27, 2021 7:41 pm
MadMotoUK
Reactions:
Post by MadMotoUK » Sun Feb 28, 2021 4:33 pm
The 3HE (1989ish) FZR600 has a cooler. As the frame and engine castings are pretty similar, if not near identical on paper, maybe this could be a source? You'd have more luck than specifically searching for 2TK parts.
EDIT: I'm assuming the 2TK has an oil cooler mounted inline with the oil filter?
Also, the FZ400 has an oil cooler (as well as water cooling), but these are probably as rare as, if not rarer than, the 2TK. I've never known one other than mine in the UK.
macbook
Reactions:
Post by macbook » Mon Mar 08, 2021 7:09 pm
Thanks, everyone for the input. I have solved my issue and then some. I have ended up gathering two complete used systems from Japan. At some point I will sell one it anyone is interested.
macbook
Reactions:
Post by macbook » Fri Mar 12, 2021 3:56 am
Thanks every one for your help. I have found a set in Germany ebay NEW! and a 2TK part number!
