3TJ top engine bolts
Posted: Sat Jul 29, 2017 5:34 pm
by hardhat_harry
Anyone know the length of the M10 top frame/ engine bolts on a 3TJ? Mine are missing
Re: 3TJ top engine bolts
Posted: Sat Jul 29, 2017 8:39 pm
by Evilchicken0
You definitely want them
Posted: Mon Jul 31, 2017 6:20 pm
by Robotnik
Hi
2x 40mm bolts and 2x 55mm bolts.
I think they are 10x1mm thread.
Neil
Posted: Tue Aug 01, 2017 7:15 pm
by icklepob
Does anyone know the length of the lower engine mount bolt that passes through the side stand bracket ?
Sent from my SM-G950F using Tapatalk
Posted: Wed Aug 02, 2017 3:22 pm
by Robotnik
icklepob wrote:Does anyone know the length of the lower engine mount bolt that passes through the side stand bracket ?
I'll find out in a day or so, I've got one fitted to a rolling chassis.
I have to get the rolling chassis out the shed and remove the bolt to measure it, I'll do it when the rain stops :)
Neil
Posted: Fri Aug 04, 2017 4:33 pm
by Robotnik
The lower bolt which goes through the sidestand mount is 185mm
The top rear engine mount bolt is 265mm and the Spacer bush which fits onto it is 57mm.
Written in text in case the pictures disappear one day :)
Neil
Posted: Fri Aug 04, 2017 10:41 pm
by icklepob
Mega,thanks for taking the time to sort this info.
Posted: Sat Aug 05, 2017 9:27 am
by Evilchicken0
Just remember those long bolts are wasted and the leg th is for the 3tj
Posted: Sun Aug 06, 2017 11:19 am
by Robotnik
No worries, I'm pleased to help.
Neil
