Genesis/2TK parts similarities?
- Kayla850
- Reactions:
- Bike owned: Sunn Tzar S2
Are the Genesis and 2TK subframes interchangeable? ie Will the 2TK ally subframe fit on a Genesis main frame?
www.projection-racing.com
www.pjcfasteners.com
- Reactions:
Re: Genesis/2TK parts similarities?
Apart from the tail bodywork I don't think the subframe carries anything on a racebike (I pressume thats what it's for). Some rules says there has to be a rear light, you can get an adhesive LED one from hein grerik though.
So could you just rig something up with ally angle or channel section ?
- Reactions:
- Bike owned: 1988 FZR400U CDN Model
As far as i know the mount points are all the same, so in theory , it should bolt up.
- Kayla850
- Reactions:
I need to cobble something up to take a different seat unit seeing as how mine got smashed up at the weekend, if I need to make a new one I might as well advertise the ally one for sale. If it fits the Genesis as well that'd be handy.
- Reactions:
2tk subframe bolts straight up no problemo. From memory though the shock eye diameters are different (10-12mm I think) I dont think this will trouble you for more than a minute Kayla. I'm not sure if the plastics mount differently ...I'll try and check tomorrow if I get a chance.
Just re-read the op....yep it mounts up!
- Kayla850
- Reactions:
Thanksbarryfzr wrote:2tk subframe bolts straight up no problemo. From memory though the shock eye diameters are different (10-12mm I think) I dont think this will trouble you for more than a minute Kayla. I'm not sure if the plastics mount differently ...I'll try and check tomorrow if I get a chance.
I've sorted the problem out now, I decided to keep and use the 2TK subframe and moved the seat unit brackets on the top rail about 40mm further forward to fit the seat unit I'm using.
- Reactions:
Hey Kayla old thread I know but too lazy to start a new one :)
I saw you talking about running 4dl wheels on the fzr400 on another forum. I bought a set and they seem very spindly. Does anyone use them? and more importantly do they stand up to the abuse? cheers
- Kayla850
- Reactions:
That must be an old-ish thread, I sold the 400 at the end of last year! I'd happily chuck them in a 1WG if that helps allay your concerns.barryfzr wrote:Hey Kayla old thread I know but too lazy to start a new one :)
- Reactions:
Have you seen anyone using them chwck?Kayla850 wrote:That must be an old-ish thread, I sold the 400 at the end of last year! I'd happily chuck them in a 1WG if that helps allay your concerns.barryfzr wrote:Hey Kayla old thread I know but too lazy to start a new one :)
- Kayla850
- Reactions:
No I haven't.barryfzr wrote:Have you seen anyone using them chwck?Kayla850 wrote:That must be an old-ish thread, I sold the 400 at the end of last year! I'd happily chuck them in a 1WG if that helps allay your concerns.barryfzr wrote:Hey Kayla old thread I know but too lazy to start a new one :)
