Can you see what it is yet
Reactions:
Re: Can you see what it is yet
Post by Evilchicken0 » Tue Mar 29, 2016 1:22 pm
Next little job was the fuelling it wouldn't idle and riding trying to hold the idle on the throttle is a pain. I asked about and turned the air screws in which helped, but not much. So I raised the needles (it has a can on the exhaust) and now it runs a lot better ... it hangs slightly and when I ease the choke off the revs rise a bit so I'll turn the air jets out this time to make it a tad leaner.
I got a pair of frame covers a while back, the left one had a bit of damage so I used some wet'n'dry filled the fork brace hole and lacquered them.
Finally I gave it a wash and put the fairing back on ... the left side fairing isn't sitting right (unsurprising cos it went down on that side) so I guess the front subframe and fairing mounts need a bit of a "massage", but which realignment tool to use ? ;)
1966baz
Reactions:
Post by 1966baz » Wed Mar 30, 2016 7:42 pm
Looking good mate. Took my 3tj out for MOT and a blast , so much fun cornering. You don't need 180 bhp on the roads, 60 is enough most of the time.
Reactions:
Post by Evilchicken0 » Wed Mar 30, 2016 8:39 pm
I don't ride that quick anyway :)
Robotnik
Reactions:
Bike owned: 2x3tj xs650
Post by Robotnik » Wed Apr 06, 2016 11:28 am
That is looking very tasty.
I've just been reading through the complete thread, It gives those of us with a bike in bits an example to follow.
Keep up the good work.
Reactions:
Post by Evilchicken0 » Wed Apr 06, 2016 8:38 pm
Cheers :)
Hope the thread / pics help you put it back together
Reactions:
Post by Evilchicken0 » Sat Apr 09, 2016 11:59 pm
Well got the fairings as close to Ok as I can, things seem to line up and look Ok.
Had some idling problems which I thought was the can. Eventually it wasn't starting well and the battery was getting a bit tired. I pulled the carbs off, cleaned the the jets, got some new plugs and recharged the battery. Got it started today and adjusted the idle ...
Runs and idles really well. Happy with it now.
Time to sell it.
Reactions:
Post by Evilchicken0 » Tue Apr 12, 2016 9:17 am
So here are the pretty pics
I guess over the next couple days I'll write up an ad and the next post will see it on Das Bay .... been a bit of a long haul
Morespeedvicar
Reactions:
Post by Morespeedvicar » Thu Apr 14, 2016 2:36 am
That looks great dude. Job very well done.
Clanky
Reactions:
Bike owned: FZR 400 3EN1, FZR 600 3HE
Post by Clanky » Fri Apr 15, 2016 1:52 pm
Great thread, lots of useful info in there, and a lovely bike. Hope you do the same with your next project.
Reactions:
Post by Evilchicken0 » Fri Apr 15, 2016 4:55 pm
The next one should be better. My starting point is a bit further on from this one.
