3EN1 Pads & Seals ........
- Reactions:
Hello .....
Now looking for fork seals & brake pads for my FZR1-Z Project ....
Its fitted with 1WG 3EN1 running gear from 1988 ....
Will this stuff fit as the 3EN1's a Grey Import ?
Thanks ...
Fred.
Stuff : ......
http://cgi.ebay.co.uk/Yamaha-FZR400-SC- ... 286.c0.m14
http://cgi.ebay.co.uk/Front-HH-Brake-Pa ... .m20.l1116
Thanks ...
Fred.
Stuff : ......
- Reactions:
Re: 3EN1 Pads & Seals ........
the fork seals should be fine, its what i got for mine! the brake pads can be a bit of a lottery, there seem to be a few different styles fitted to em! if you've got a pic i can tell you if its same as mine and give you the part number for the brake pads.
- Reactions:
Hi Taggy,
Thanks for the offer of help M8 .....
Attached should be a picture of the Sunimoto calliper ...
Fred.
Fred.
- Reactions:
aye they look like mine!!! both pistons the same size! i used pads with the number fa123 thats for ebc HH but if you give that to a parts place they'll be able to find the equivalent other makes from their books. try it as a search in ebay and you'll see what i mean!
hope it helps!
ps the rear should be an fa104
hope it helps!
- Reactions:
Thanks very much M8 for all your helpTaggy wrote:aye they look like mine!!! both pistons the same size! i used pads with the number fa123 thats for ebc HH but if you give that to a parts place they'll be able to find the equivalent other makes from their books. try it as a search in ebay and you'll see what i mean!
hope it helps!
Fred.
