Starting problems
Pinwood400
Reactions:
Starting problems
Post by Pinwood400 » Sun May 27, 2018 5:22 pm
Hi I’m new to the forum but hoping someone can help. I have a cbr 400 nc23 1988, j
I brought it last June and have been bringing it back to life since. It was all going well until last week. The bike has been run on a number of occasions and sounded sweet. But now will not even turn over. I have a new battery, new starter solenoid, new ignition, I’ve checked the kill switch and starter button. All seem fine. As is the neutral switch. The starter solenoid doesn’t even click, but if you place a screwdriver across the terminals the bike turns over. I am quite a novice at mechanics / electrical and am pulling my hair out.
Any ideas???????
dunkenb
Regular Member
Reactions:
Re: Starting problems
Post by dunkenb » Sun May 27, 2018 5:38 pm
Have you checked the fuse in the starter relay?
Pinwood400
Reactions:
Post by Pinwood400 » Sun May 27, 2018 5:40 pm
Yes all fine, even tried another just to be sure
dunkenb
Regular Member
Reactions:
Post by dunkenb » Mon May 28, 2018 1:06 pm
Checked the earths? Try bridging the starter button?if it’s not clicking check your ignition switch too ..
Pinwood400
Reactions:
Post by Pinwood400 » Mon May 28, 2018 7:37 pm
Found the problem. Seemed to be a break in the wire from the fuse box to the starter button. Replaced the wire and fired up a treat. Thanks for your help with the problem, much appreciated
dunkenb
Regular Member
Reactions:
Post by dunkenb » Tue May 29, 2018 12:27 am
Glad you sorted it it’s a pain in the arse when you have to spend hours fault finding
