NC23 forks!! Air pressure ??
geoff916
Reactions:
Bike owned: CBR 1100 XX, CBR 400 RR CBR
Post by geoff916 » Thu Sep 21, 2017 6:06 pm
Hi
Now I have her running sweet as a nut....I am turning to the suspension.
There are shcrader valves (Tyre thingys) on top of the fork legs.
what is the correct pressure / amount of oil please ?? :?: :?:
(I do like hard suspension)
Thanks in advance for any help
Geoff
CB1pod70
Reactions:
Re: NC23 forks!! Air pressure ??
Post by CB1pod70 » Fri Sep 22, 2017 3:35 pm
I think the general advice these days is not to put any air in the forks. Anything more than a few PSI puts a strain on the fork seals and the air soon escapes unless everything is in perfect condition
If you need to uprate the forks then you should be looking at uprated spring or heavier oil
stonecreator
Reactions:
Post by stonecreator » Sat Jun 30, 2018 11:51 am
I use a push bike small pump and through trial and error for the track I am now much more comfortable with 5/6 pumps, no problem with seals leaking.
Return to “CBR - Workshop”
