Front brake master cylinder hose NC29
- Reactions:
Hi Everyone
The short rubber pipe connecting the front master cylinder reservoir to the master cylinder needs replacing on my cbr400 NC29 1990 model.
Had a look on CMSNL and found part number 45512-MR7-006 but unfortunately no longer in stock anywhere i can see.
So im wondering if this part of the braking system would require a low pressure hose compared to the lower brake lines as i can then get some low pressure hose fairly easily.
has anyone tried replacing this part before? at the moment this seems to be a decent alternative http://www.ebay.co.uk/itm/APS-Low-Press ... SwaNBUfMvD
Thanks for your help
Sam
Sam
- Reactions:
Re: Front brake master cylinder hose NC29
Hi Sam,slyshot wrote:Hi Everyone
Sam
Yes it is only a low circuit as it comes from the brake fluid reservoir.
Cheers,
Kevin
Sent from my SM-G900I using Tapatalk
