Nc23 k&n style air filters
Dgeezer
Reactions:
Post by Dgeezer » Fri Jun 29, 2018 12:33 pm
Hi everyone
Does anybody know if you can fit a set of k&n style cone air filters on the nc23,after just taking the carbs off it doesn't look like a standard fit
Thanks in advance
CB1pod70
Reactions:
Re: Nc23 k&n style air filters
Post by CB1pod70 » Fri Jun 29, 2018 1:36 pm
Keep the airbox, you're entering into a whole world of pain otherwise. A good mod is to cut out the standard paper element and replace with filter foam. I've recently done it on a CB-1, have a look here viewtopic.php?f=62&t=54169&start=10
Dgeezer
Reactions:
Post by Dgeezer » Sat Jun 30, 2018 8:04 am
I plan on turning the bike into a streetfighter just for a change and need the room where the airbox is to relocate the battery and the rest of the wiring,it's not a performance mod I'm trying to do
moforockband
Reactions:
Bike owned: GK73a SP CRM250 mk3
Post by moforockband » Sat Jun 30, 2018 9:45 am
The bike won't run properly without the airbox. Your carbs are 'constant velocity', which means they need smooth air flow at all revs/throttle.
Consider using a lithium battery, as you can mount them sideways and thy come in many shapes/sizes.
CB1pod70
Reactions:
Post by CB1pod70 » Mon Jul 02, 2018 12:57 pm
If you're just trying to create space behind the tank for a battery why not bin the standard coils and do a stick coil conversion (CBR600 stick coils fit). You gain space, better spark generation & no carb issues - There are plenty of articles covering this conversion.
Dgeezer
Reactions:
Post by Dgeezer » Tue Jul 03, 2018 10:09 am
Thanks for the advice guys it's great to have access to such knowledgeable people looks like I have a few things to look at 😁
Return to “CBR - General”
