Rs250 seat on nc30
- Reactions:
Rs250 seat on nc30
Does anyone know what model rs250 seat fits the nc30? Aprilla, rsw250 etc.
I have a rs250 Honda seat resting on a custom sub frame but it needs so much modification i may as well go back to standard?
Muzz
Muzz
- Reactions:
Re: Rs250 seat on nc30
the honda rs250 seat unit fits really easy.
it still uses the original mounts too.
all you need to do is cut a Y shape in the seat pad area. then stretch it open about 1 inch or so.
put a 1.5mm plate into the seat base for strength and then fibreglass over it.
it mounts directly onto the original nc30 mounting points
- Reactions:
Would you know what year rs250? Thanks
- Reactions:
1993 to around 2000 year fits very well
- Reactions:
Thanks. Will give it a go. Turned out to be an expensive mistake
- Reactions:
the custom subframe was expensive mistake?
