Brake upgrade
- Reactions:
- Bike owned: Rvf baby
Brake upgrade
Hey guys, looking to upgrade the front brakes on my nc35. At the moment she is completely standard. I did a trackday on her last month and felt the brakes are very poor so want to upgrade. What are peoples choices of master cylinders and calipers?
- Reactions:
- Bike owned: '89 NC30 T1, '92 NC30 T8
Re: Brake upgrade
You shouldn't need to upgrade the brakes, anything more than factory is overkill. Are they in good condition? Good pads? Pistons clean?
- Reactions:
Re: Brake upgrade
Cbr600 fi caliper they have a bigger piston 34mm and 32mm sbs duel carbon pads but they don’t like rain and any 19mm master cylinder. Get a brembo 19 20 is u got the cash and braided lines both from master cylinder about the best set up Iv tried
- Reactions:
Re: Brake upgrade
Are the cbr calipers a direct fit then?
- Reactions:
Re: Brake upgrade
If u have rvf400 then they go straight on 1999 until 2002 I think. if u are just doing track days u could just get a 17mm radial brembo and keep the rvf calipers U probably won’t notice the difference
- NGneer
- Reactions:
Re: Brake upgrade
What he said.
Matty, if you feel your brakes are "poor" I would suggest a full Service of the callipers (new seals, polish Pistons, new fluid and bleed). If you do that, which is also the cheaper, quicker and easier option, I strongly suspect you will be suitably impressed with a "refreshed" standard set up. If not you can always go down the more exotic/expensive route later.
All mine are standard and on the track I can easily get the rear wheel 'floating' as I am braking for the Corner at the end of the straight at Cadwell. Who needs anything more
- One Hit Wonder
- Reactions:
Re: Brake upgrade
Correct me if I'm wrong, but aren't the calipers the same as a 929 blade?
- Reactions:
- Bike owned: 1994 RVF400R
Re: Brake upgrade
Original condition
Vapor blasted, complete rebuild, brembo res, custom bracket
Original front caliper condition
Bead Blast and powdercoated, new OEM seals and Titan Classics Ti pistons, bleeder, etc, EPFA pads, HEL stainless lines
Rear caliper and master vapor blasted, full rebuild, Titan Classics Ti pistons, bleeder, etc, OEM seals and rubbers, Tyga Res, HEL Stainless line
Motul RBF600 brake fluid. They work pretty damn good. Careful attention to detail, assembly and bleeding and the stock stuff works excellent.
