Speedo De-restrictor Resistor
- TZcRank
- Reactions:
Can anybody confirm that this is indeed the 2k Resistor required to bypass the Speedo Restiction?
- Reactions:
Re: Speedo De-restrictor Resistor
From the info I have you should be using a 2.2k ohm resistor which has the colour bands:
red, red, red, gold
red, red, red, gold
- TZcRank
- Reactions:
Hmmmm ok. In the guide posted in the resource section it states 2k. Thanks for the reply Ronin.
- Reactions:
- Bike owned: VFR400
2k or 2.2k, makes no difference.
- TZcRank
- Reactions:
Excelent! Thank you Magg
