RVF400/VFR400 Water Pump
ZippiT
Reactions:
Post by ZippiT » Thu Dec 13, 2018 5:45 am
Hello,
I was wondering if anyone has successfully split/gutted the water pump housing that holds the impeller/shaft?
Reactions:
Re: RVF400/VFR400 Water Pump
Post by CMSMJ1 » Thu Dec 13, 2018 9:48 am
you can get a blanking plate to remove it if you are running an electric pump - is that what you mean?
ZippiT
Reactions:
Post by ZippiT » Thu Dec 13, 2018 10:43 am
Looking to remove these parts from the water pump housing
Reactions:
Post by CMSMJ1 » Thu Dec 13, 2018 1:25 pm
ahh - not sure I've known someone strip it that far back - mostly it is a replacement as a unit
