Rear wheel
The Novice
Reactions:
Bike owned: NC23 NC30 CRM250
Rear wheel
Post by The Novice » Mon Oct 01, 2018 6:39 pm
I have removed the large nut and spacer but the wheel won’t come off. Is anything else holding it on or do I need to go at it with a hammer? It has stood for 5 years so I fear its stuck solid
Suzuki416
Reactions:
Re: Rear wheel
Post by Suzuki416 » Mon Oct 01, 2018 7:38 pm
Reattach nut - with it undone 3 or 4 turns.
Put bike on the ground, on the wheels, hit the TYRE from left to right with a large 2 x 4 block of wood at the back of the bike (1 hit - IT DOESN'T NEED TO KNOCK OUT MIKE TYSON) - roll forward 1/4 turn do the same again - repeat around the wheel.. once the wheel has moved so its touching the nut put it back on the stand, undo nut & it should then come off.
