nc35 project, help needed please
Posted: Sun Jun 10, 2018 3:06 pm
by branc35
Hi
Just got an nc35 project bike , few issues, fork damper adjusters are siezed and fork seals are leaking, the preload adjuster on right fork doesnt screw down to remove circlip, just spins but can be pushed down but middle part moves down with it.
Indicators dont work, there is a datatool alarm fitted which flashes them, have checked switch and its fine and also have power going to the relay, I have tried another relay but still nothing.
Re: nc35 project, help needed please
Posted: Mon Jun 11, 2018 3:37 am
by magg
LED indicators?
Posted: Mon Jun 11, 2018 5:52 am
by branc35
Think they are
Posted: Mon Jun 11, 2018 6:48 am
by magg
LED indicators do not load the flasher relay sufficiently. You can add resistors or change the relay type. The alarm probably does not care what type of indicators are fitted.
Posted: Mon Jun 11, 2018 1:36 pm
by branc35
thats great thanke ill try some different ones
Posted: Mon Jun 11, 2018 7:00 pm
by branc35
Well you were spot on, tried on a normal indicator and they work, had some standard ones ordered anyway as I dont like the look of the ones on it.
Thanks for the help
Posted: Tue Jun 12, 2018 12:42 am
by magg
The "middle" part of the adjuster can be screwed up and down independent of the preload adjuster. You have haynes manual, not a bible but has the basics right most of the time.
Posted: Tue Jun 12, 2018 7:36 pm
by branc35
thanks got them apart today, threads on alloy part damaged and were not attached to the cap
