Open / close throttle driveline shunt
andut1
Reactions:
Bike owned: NC30 & 400/4
Post by andut1 » Wed May 09, 2018 2:24 pm
Ever since I have had my NC30 it's been a little 'clunky' when initially opening or finally closing the throttle, especially noticeable at low speeds - not a massive problem most of the time, but sometimes a little annoying in traffic. Is this a normal NC30 'characteristic' or something that can be adjusted / tuned or repaired ?
Thanks for any thoughts or suggestions !
Andy
gavins
Reactions:
Bike owned: NC30, ER6f, K5 750
Re: Open / close throttle driveline shunt
Post by gavins » Wed May 09, 2018 2:52 pm
First thing that springs to mind is too much chain slack. Is your chain properly adjusted?
magg
Reactions:
Bike owned: VFR400
Post by magg » Thu May 10, 2018 7:49 am
No rubber in the drive train like most road bikes means that it can be a little clunky/snatchy when on/off throttle is not perfectly smooth.
Reactions:
Post by CMSMJ1 » Thu May 10, 2018 4:47 pm
you'll get used to it :) it is a feature of no cush drive as magg said.
andut1
Reactions:
Post by andut1 » Fri May 11, 2018 12:25 pm
Thanks gents - good to hear it's likely to to be normal !
Reactions:
Post by Neosophist » Fri May 11, 2018 5:43 pm
could also be rough if the carbs are not set up quite right, having a properly dialed in low end does make a lot of difference on a biek without a cush-drive.. pilots could be too lean / rich (dirty or clogged / pilot screws open too much)
carbs out of balacne.
the lack of cush drive will make the grab a bit rough if your not smooth on the throttle.. if its jerky uneven it might be carb settings.
moforockband
Reactions:
Bike owned: GK73a SP CRM250 mk3
Post by moforockband » Sun Jun 17, 2018 9:31 pm
Use a front sprocket with rubber damping will alleviate some of the issue. Pretty sure my original 92 nc30 had a rubber damped sprocket from brand new.
hunter
Reactions:
Post by hunter » Sun Jun 17, 2018 11:04 pm
If i remember rightly so did the rear.
