NC24: Rear Wheel <-> Sprocket clearance normal?
- Reactions:
Hey guys,
is it normal that I can turn the rear wheel (while on a jack) about 0,5cm to 1,0cm before the sprocket/chain starts moving?
I have mentioned the clearance this Weekend while cleaning the bike. Is it normal on the NC24
Or do you think that the dampers are worn out? See number 2:
https://www.cmsnl.com/honda-vfr400rii-n ... ml#results
greetings
Kai
greetings
Kai
- Reactions:
Re: NC24: Rear Wheel <-> Sprocket clearance normal?
sounds normal, its the slack in the cush-drive rubbers..
you can take off the cushdrive cover to see the actual phsyical condition of the rubbers..
