Home-made headlight rubbers (with template)
mwarriner
Reactions:
Re: Home-made headlight rubbers (with template)
Post by mwarriner » Sun Feb 28, 2016 8:53 pm
All,
Please find below a template for the NC30 headlight rubbers. Please be aware that I am not a graphic designer so whilst I am happy to use the template to create replica rubbers you do so at your own risk ;)
Do bear in mind that the rubber I used as a template was badly wrinkled so if anyone can improve on the template that would be very welcome.
The scale on the template is, of course, mm and the template does therefore not fit on a single A4 sheet but hopefully putting the image on two sheets, with overlap, and lining up the two sheets should be simple enough.
Best,
Mike.
jim157
Admin NWAA
Admin NWAA
Reactions:
Bike owned: A few small ones
Post by jim157 » Sun Feb 28, 2016 9:01 pm
Top work, thanks.
AUTOEXEC.TWAT
CoastalRider
Reactions:
Post by CoastalRider » Thu Feb 08, 2018 7:50 pm
this might be old - but thank you so much! very helpful!
saltysealion
Reactions:
Post by saltysealion » Fri Feb 09, 2018 3:41 am
Nitrile rubber....with the temps it can withstand, sounds like that can be used to create the engine heat shields as well?
Those shields are now NLS, and second hand are ridiculously expensive.
Kabmoto
One Hit Wonder
Reactions:
Post by Kabmoto » Tue Apr 14, 2020 6:52 pm
Is it possible for someone to repost this template as its no longer available?
Thanks in advance!
