NC35 emulsion tubes
sniff
NC35 emulsion tubes
Post by sniff »
Mixed up the tubes when cleaning, which set goes to rear bank?
My initial thought is top ones, with the lower hole, to rear cylinders, but....many thanks
watafu
Re: NC35 emulsion tubes
Post by watafu »
If I remember correctly, 5holes for the rear cylinders and 4 for the front cylinders, if in doubt check out the carb guide on this forum
Cammo
Post by Cammo »
sniff wrote:Mixed up the tubes when cleaning, which set goes to rear bank?
Your thoughts are correct, the top 2 tubes in the pic are for the rear cylinders. :up:
watafu wrote:If I remember correctly, 5holes for the rear cylinders and 4 for the front cylinders, if in doubt check out the carb guide on this forum
That info applies to NC30's only, rvf parts are quite different.
sniff
Post by sniff »
many thanks...
