vfr400r valve adjust
The Big Taveri
Reactions:
Bike owned: NSR250MC28 CBR250MC19 VFR400R
Post by The Big Taveri » Sun Dec 11, 2011 10:05 pm
Hello, The my Nc30 after 13000 miles has a ticking of valves !! (rear head)
Question:I can use my bike for others 1500 miles ??'
I don't know tappet clearance, you can help me!
The Vfr400 have defect of usury cams as vfr750 f ??(cam damage) :pray:
Thanks :lol:
Alessandro
Davez29
Reactions:
Bike owned: NC29 forever
Re: vfr400r valve adjust
Post by Davez29 » Sun Dec 11, 2011 10:08 pm
Hi mate, theres a full guide to sorting this in the vfr part of the forum.
here: viewtopic.php?f=24&t=1943
Cammo
Reactions:
Post by Cammo » Mon Dec 12, 2011 12:01 am
The ticking noise is common and doesn't necessarily mean that valve clearances are out in my opinion.
There's only one way to find out though.
The Big Taveri wrote: The Vfr400 have defect of usury cams as vfr750 f ??(cam damage) :pray:
The nc30 doesn't suffer the same cam problems as the vf750. Actually, I don't think any other honda model was affected with the same problem.
The Big Taveri
Reactions:
Post by The Big Taveri » Wed Jan 11, 2012 10:29 pm
Thank you very much. ;)
The next week I will control the valve clearance with oil and filter change (Motul 5100) :mrgreen:
Alessandro
viper_biker
Reactions:
Post by viper_biker » Thu Jan 12, 2012 1:47 am
Slack cam chain??? ;)
porndoguk
Reactions:
Post by porndoguk » Thu Jan 12, 2012 10:04 am
viper_biker wrote:Slack cam chain??? ;)
NC30 :whistle:
Reactions:
Post by Neosophist » Thu Jan 12, 2012 1:12 pm
NC30 :whistle:
lol vipers was a joke :P
the problem with the vfr750 was the oil passage to the top end was crap design and too small.. it was easy to block and have low pressure / no oil to your cams which cause them to wear themselves away :/
Shame really, decent engine baring that (you can replace the top end lines with franken-kits' that look pretty awesome)
On topic.. follow the valve clearance guide... check them even if you don't adjust them.
You can ride it as many miles as you want until it explodes..but putting off vital checks isn't good.. many times you can get away with it damage free.. sometimes small damage occurs and other times it's major damage.
It doesn't take too long to just check the clerances.. at least if you write them down you'll have an idea how much wear is in them..
Robert26
One Hit Wonder
Reactions:
Post by Robert26 » Sat Nov 18, 2023 2:30 pm
Hi... i have a quick two questions. Does the cam journal that is in the 'Long hole" on the cam holder actually touch the holder? How is it supported? Also, has anybody ever done anything with needle bearings on the cams?
Thanks in advance,
Robert
