NC35 bodywork on NC30
- Reactions:
Has anyone used NC35 bodywork on a NC30?
Obviously it's possible on the basis that anything is with the right amount of modification. How easy is it because I assume it won't be a straight swap.
How hard can it be?
- Reactions:
Re: NC35 bodywork on NC30
track fairrings ? or road ?
Tracks go on without a problem as i have just done a set myself
road would be diffrent as diffrent lights etc
- Reactions:
No road.
The headlight apertures are certainly different shapes, don't know if the headlights would actually align to accepted tolerances.
How hard can it be?
- Reactions:
no idea on that m8, all i can tell you Track fairings for the nc35 fit on my nc30 :)
- Reactions:
To fit a road nc35 upper cowl you would need the front subframe, headlights and screen brace. The mids and lowers should go on ok.
For the rear you would need an nc35 rear subframe.
- royster81
- Reactions:
and the front subframe isn't a straight swap you'll need to redrill a hole .
- Gavin jap4
- Reactions:
eamer1989 wrote:no idea on that m8, all i can tell you Track fairings for the nc35 fit on my nc30 :)
royster81 wrote:and the front subframe isn't a straight swap you'll need to redrill a hole .
sounds correct to me
- micpec
- Reactions:
a member on this forum called Yack done it a couple of years ago, he turned his NC30 into a nice NC35-RT lookalike.
As said by others, you will need of an NC35: front clock/fairing stay, rear subframe plus lower fairing bolts(!),
front headlight unit and maybe the mirror fairing stay. As for the panels, NC35 rear seat panels, mid panels and
top fairing panel.
(I have the majority of the mentioned NC35 parts above here somewhere stuffed, it will be for sale soon).
top fairing panel.
- Reactions:
Might have go and make it fit. I've been looking for some half decent bodywork but do't want to spend more than £50.
How hard can it be?
- monkeywithaplan
- Reactions:
- Bike owned: NC35 and NC30
just get a nice NC35
