Case savers / crash protection ???
Rushvf1
Reactions:
Post by Rushvf1 » Mon Nov 05, 2018 6:18 am
Hey, looking into case savers / crash protection for my rvf400. I've seen a few goodies including the Tyga carbon ones. If I could get some more information / ideas from you guys that would be great. 😊
Foxy400
Regular Member
Reactions:
Bike owned: NC35 NC29 Bonneville CBR600F4i
Re: Case savers / crash protection ???
Post by Foxy400 » Mon Nov 05, 2018 5:21 pm
Whatever you do, don't drill holes in your fairing! They're too valuable, although we've all seen bikes where it's been done.
Rushvf1
Reactions:
Post by Rushvf1 » Mon Nov 05, 2018 7:53 pm
No wasn't planning on it 😉. Just needing a good setup that will pass the scrutineering at the track. Maybe a home made setup might be the go.
Dynamohum
Reactions:
Post by Dynamohum » Sat Nov 10, 2018 9:19 pm
It's a tough choice some crash bungs do more harm than good might help protect bodywork frame at slow speed but can also burst cylinder head mounts or lower crankcase mounts and in worst case dig in flipping a sliding bike over .
blknoel
Reactions:
Bike owned: 1992 NC30
Post by blknoel » Mon Nov 12, 2018 3:58 am
Rushvf1
Reactions:
Post by Rushvf1 » Mon Nov 12, 2018 8:39 am
Thanks blknoel. Do you use GB one's?
SPOONDIDDLY
Reactions:
Post by SPOONDIDDLY » Tue Nov 13, 2018 8:54 am
The Tyga units work a treat and aren't badly priced.
It's also possible to weld some additional material to the engine cases or fabricate your own case savers that mount using the existing engine bolt holes.
There isn't really a lot available for these bikes though, so if you're looking for off the shelf I recommend Tyga.
Rushvf1
Reactions:
Post by Rushvf1 » Tue Nov 13, 2018 11:00 am
Cheers spoondiddly. Yep I'm thinking about going that way.
blknoel
Reactions:
Post by blknoel » Wed Nov 14, 2018 5:19 pm
No I just posted them as alternatives to Tyga, which I think is more cosmetic (could be wrong though). GBracing is involved in high level racing and I think their approach/solution for the NC30/35 a bit more rigid/functional in case of a spill.
They do cost dearer though.
Rushvf1
Reactions:
Post by Rushvf1 » Thu Nov 15, 2018 6:18 am
Yep totally understand where you're coming from. They do look the goods 😗
