Running issues
- Reactions:
Running issues
Not sure if this is normal or not though I've been assured it is by other riders here.
When running my NC30 though the city and in very hot weather the idle will drop to about 1k rpm if not maybe a little lower.
It's start a little above say about 1200 1300 rpm and when warm drops. It's when I pull up to the lights or the a U turn that the idle will drop and then engine will stall. Mind this is during very hot weather and the temp gauge reading up past 90 degrees.
I'd this a normal thing. I've been told to blip the throttle at the lights or at any stand still really to keep it from doing this.
Thoughts?
Sent from my CPH1723 using Tapatalk
Thoughts?
- Reactions:
Re: Running issues
Its running rich at idle.
- Reactions:
Re: Running issues
OK Im gonna sound like a Muppet but till my copy of Haynes gets here I need some advice, so how do I adjust the ratio so it's not too rich?Neosophist wrote:Its running rich at idle.
- Reactions:
- Bike owned: VFR400
Re: Running issues
Home page has document library that has copy of Honda service manual. The manual identifies the pilot screws and the standard setting. If the standard settings of two turns out does not fix the problem, then less turns is leaner.
- Reactions:
- Bike owned: VTR250 / VFR400
Re: Running issues
Did you fix the problem? This is just the same problem I had recently.cvondetten wrote:OK Im gonna sound like a Muppet but till my copy of Haynes gets here I need some advice, so how do I adjust the ratio so it's not too rich?Neosophist wrote:Its running rich at idle.
You can adjust the mixture screws with a long (30cm) flat bladed screwdriver. Take off the upper side panels only and with a torch between the cylinder heads, you can see the screws. Not super easy to turn, but doable.
Sent from my ASUS_Z01BDA using Tapatalk
